I've got a '97 Mountainer, 5.0L V8. I'd imagine it's pretty similar to your vehicle.
The sounds decently simple. Is there any chance you could take a picture of the location and circle it in paint or something? Sorry for the bother! Alternatively, if you know of a tutorial or something, please do let me know. I did a search on the forums, but didn't find instructions.
If you don't mind me asking, what type of access problems might I encounter, and how do I deal with them?
Sorry, but I don't have any way to do pics; and it's been a couple of years since I did mine. By "access issues" I mean being able to get wrench or an O2 socket w breaker bar on the old sensor with enough room to turn it. I have access to a lift, which is much easier, but the job can be done with the vehicle up on ramps/jack stands.
Best advice I can give you is:
- Slide under pass side of truck just behind front tire and look for the sensor. It will be in the exhaust pipe behind the second cat but in front of the muffler.
- There will be either three or fours wires (probably four) coming out of the sensor. (IIRC, all four O2 sensors plugs are on top of the transmission, so the wires will run up on top of the transmission to a socket. But I may have my vehicles confused - I have several different ones I work on.
- Go to one of the auto parts stores and rent/borrow an O2 sensor socket set.
- Get some PB blaster to spray on/around the socket. Hopefully, this vehicle has spent it's life in the South, so rust won't be so big an issue.
- Unplug the sensor before you unscrew it. You can cut the old wires off to get them out of the way - but then you are committed to the replacement!
- Don't buy a "generic" O2 sensor replacement. Get one with the correct wire lenght/plug already on it; worth the extra money.
- Make sure there is anti-seize on the new sensor; most come with it - if not, buy some and add it. Screw in the new one before you plug it in.
Good luck - sorry I don't have pics - maybe someone else can post some???
