liquid217
- June 25, 2003
- Owensboro
- '97 explorer
Hi Guys. I have a 97 explorer 4.0 OHV that has been giving me the codes P0171 and P0174. The odd thing is that it only occurs when the outside temperature drops below ~45 degrees F. The truck has a slightly rough idle, but nothing in my opinion to be concerned about. I have done a great deal of checking on this issue, ranging from looking for vacuum leaks, cleaning the MAF, etc. I replaced all of the O2 sensors last year, so I know they are fine. I have a fuel pressure tester and at KOER, I get a pressure of 30psi. With the vacuum line off of the regulator, it jumps to appx 38psi. (There was no fuel in the line, FYI) If I shut the engine off, it holds pressure for several minutes.
These DTC's seem to come back almost as soon as I clear them when the temperature outside is in the 30s. Also, my scanner tool can tell me if it is passing the readiness tests. It has been unable to perform the catalytic test for quite some time. This weekend, I decided to pull the vacuum line off the regulator, and cap it (Using PVC tape). I decided to drive around with it like that. To my surprise, not only did the DTC's NOT return, but it also completed the catalytic readiness test. So my question is this, does this sound like a fault with the fuel pump, or the regulator?
