andrew 2000 XLT V8
- August 9, 2022
- Everett Wa
- 2000 Explorer XLT 5.0 V8
I have a 98 Ford Explorer XLT 5.0 V8 that has the codes p0171 and p0174 lean on both banks and it is idling really rough and the exhaust sputters. Sometimes won’t go above 2500 rpm runs ok(not great) when driving/ coasting but when I stop if feels like it’s going to stall. I have recently replaced the ignition wires, coil packs, spark plugs, fuel injectors, fuel pressure regulator, all 4 oxygen sensors and the upper intake gaskets(plenum to block, egr housing to plenum, and throttle body to egr housing) problem is still there. I got a smoke test done and shows no vacuum leaks. I am now lost no idea what it could be. Any ideas greatly appreciated
