tlestan
- March 19, 2010
- Wisconsin
- '99 Mercury Mountaineer
THIS PROBLEM IS SOLVED. JUST EDITING SO PEOPLE DON'T HAVE TO ADD IDEAS. IT WAS FUEL PUMP
OK, I've read EVERYTHING related to these lean codes. 1999 Merc Mountaineer with 4.0 SOHC. Replaced the upper and lower intake gaskets, curing the rough idle when cold - still get the codes even in summer. Truck runs great, but hot starts are getting a little weird. Read the MAF signal with a scanner, and all looks good. Short term fuel trims running at 15 on one bank and 6 on the other. Did thourough check for vacuum leaks with propane and visual - nothing. I'm also getting P0741 on the trans when it does the flashing O/D light trick. Can these be related? Mileage is running 15-16, and it used to be 20. No codes for O2 sensors, except a pending P0137 one time, but real time signals look OK. Could TPS be an issue? Just cleaned the MAF tonight, running at .82 at idle, and smooth through the range. Can anyone give me a new outlook on this? Fuel pressure is rock steady at 33. Truck has 230,000 miles on it. Just getting broke in.
