pclarke1
- July 24, 2007
- Fargo ND
- 1996 Eddie Bauer 4WD
Hi all, first time caller, long time listener!
Been having an intermitant CEL issue for a while now. It seems to only come on when the engine is hot. It runs, but idles rough. 90% of the time it is a P0306, occasionally it has thrown a P0300 (not very often, but it has happened). I had a less severe version of the problem last summer, but this seems to dissappear over winter (I live in Fargo ND). Which is why I suspect something to do with resistance.
My first step was to replace plugs and wires, then I replaced the coil pack. I am now in the process of replacing the number #6 injector. I checked the resistance on all injectors and they were between 0.16 and 0.17. So where I am right now is that I have the fuel rail apart and the injectors are out at the cleaners. They are all being cleaned and tested even the one I suspect is bad. I have also taken the opportunity to change the fuel filer, clean the throttle body, MAF and IAC, as well as get new leads (because I did not route the new set properly and found some burn marks on the outside). I am reassembling with new gaskets and injector seals.
Ok, so a long way to getting to my questions.
1/. Apart from a bad cylinder (I have not been game to check compression), have I covered all of the bases?
2/. What type of reassembly lubricant (apart from getting myself a beer) should I use on the gaskets and injector seals.
3/. Anything else you thing I should do while I have it apart?
4/. Are the top and bottom injector O rings the same?
