Dc4704
- December 10, 2011
- 2000 Ford Explorer
I have the V6 SOHC engine and I recently replaced the lower intake manifold gaskets and IAC valve which solved the issue of stalling on startup. However, now my car is throwing a P1506 code. It idles from 1700 to 2000 at all temperatures and when i unplug the IAC it drops to 1500. This is with the idle set screw all the way out. I tried checking for leaks but I found none. Any ideas?
