Lechuga
- November 12, 2008
- Spain
- '98 XLT
My Explorer is (apparently) an early 98 with the V6 SOHC engine and the OSS in the TC, which was broken and disconnected (I used to get a P0720 DTC). I bought a replaced the broken OSS and connected it. The result is the P0720 is now gone, but it now shifts really late (around 5000-6000rpm) sometimes even hitting the rev limiter regardless how soft I drive on flat ground. Also I got two new error codes (P1714 and P1715), which disappear if I disconnect the OSS.
Disconnecting the OSS causes the P0720 back and shifting is more or less back to normal (the way it used to before).
I am hoping someone will suggest an easy fix. Because so far, nothing has been easy with this Ex and I don't particularly fancy another ATF bath (but I will do it if necessary).
So far in the last 5000 miles, I've done a full tune up, replaced the transmission VB gaskets and transmission oil filter, full oil change (engine, TC, front and rear diffs).
My gut feeling is wiring, but where to look... Any input will be much appreciated. TIA
Chris
Chris
