96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
Interesting observation: My parking brake wasn't working that well.
So I pull the rotor. Everything inside looks perfect, no problem. Was done kinda recently, I don't even drive it much, but I use the parking brake.
Then I take tension off the cables.
Nothing is binding. Both cables are pretty free.
Then I start playing with the latch mechanism. Seems the driver side does not have much up down movement. But the passenger does.
The passenger side does not seem to return to the same position as the driver when activated (but nothing is really binding with the mechanism or cable when pushed with a screwdriver, and it snaps back). Obviously the the pedal loads this much more.
I pull it apart. Seems the driver side has a "shelf" on the backing plate that supports the mechanism, but the one on the passenger side has flex! It does not support the assembly. So, when activated, things "may" slip out of place. (I think?)
The lever is free to slide down the parking shoe surface - read on...
Then I took a look at rockauto. Seems there are two styles of parking shoes. 1996 FORD EXPLORER 4.0L V6 Parking Brake Shoe | RockAuto
The Ford OEM seems to be a 745 style. (BRP-745)
There is a "701" and "745"
745: (note the extra tang - it is upside down in the pic). That would certainly support the latch. The 745 is also listed as Jeep Liberty Compatible.
701: Allows the mechanism to move out of alignment (maybe it is designed for a backing plate with a tang)
I may actually try the 745 setup. My F150 has the exact same setup, just larger. Both shoes are notched like the 745.
