Passenger door not working.... | Ford Explorer Forums
titansarrow
dayton, oh
91 explorer
i've looked for this in the forums and found a similar problem with the 2nd gen, dunno if it's the same though.
over the last few days the front passenger door would not unlock via the button, so i'd just reach over and pull the handle to open it for the woman. I could also unlock and open it from the outside (if the lock wasn't frozen). but now i can't do anything. the outer lock is frozen so i can't get in that way. and the inner handle seems to be stuck in the open position. if i smack it, it pops back into place, sounding almost as though the plastic on the handle was getting stuck on the trim, but that didn't seem to be the case.
whenever i pull it i feel normal resistance, but just gets stuck sitting in that open position. from there it has a little more pull, but nothing happens.
i don't know if it's a problem with my lock or handle...or maybe both now. i haven't been able to tear into it yet, was jw if any1 had the same problem??
I have a 92 that had a similar problem with rear passenger side door handle got to the point it would not open from inside. Mine was problem with hinges, it was slightly out of line and you had to whop it get it open, a little work on aligning it fixed the issue for me. I blame the kids swinging on the door getting out.
94 exploader
i have a 94 explorer xlt the rear pasenger door wont open from the inside or out side HELP!!!!
