imp
- November 12, 2009
- 59 Ranchero F250 D'Line
2004 Explorer, 4.0 SOHC 4X4, lately a "one-key" wonder. Been studying the Ford Wiring Diagrams diligently for a few days now, trying to see deeper into their scheme of disabling the vehicle. Much of this has been hashed & rehashed nearly to death. But I think I spotted something significant. Ya gotta understand electrical schematics......but look at this and see if I'm seeing it wrong:
Above, the only page devoted to the PATS anti-theft wiring. Note the Transceiver, which surrounds the lock cylinder in the steering column, receives it's power from fuse 2.24, and communicates directly with the PCM, no connection to the Security Module, via TX and RX. The PCM in turn acts as a switch in series with the starter relay, the PCM is therefore responsible for turning ON the starter motor, if it receives the "OK" from the Transceiver.
In the next diagram, the rest of the starter relay is shown, including the connection to the PCM. The relay coil receives power from fuse 2.29, which feeds the Neutral/Park Safety Switch, incorporated in the Transmission Range Sensor, thus showing that if the PCM closes the contact shown in it to ground, the relay will pull in, and the starter motor will be energized, and crank the engine.
I can find no other means which would prevent the engine from starting, such as disable of the ignition or injectors; both are fed straightforward with no hocus pocus involved, by the ignition switch, in either START or RUN position. Thus ANY KEY capable of turning the lock cylinder to START and RUN, will enable both ignition and injectors.
I propose that a set of contacts controlled by the ignition switch in the START position which ground the connection at C1017 or C175b, will start the engine.
Whaddaya think? imp
Whaddaya think? imp
