- February 18, 2015
- Phoenix Az
- 1991 aerostar
I bought a 422 cam and borla headers from another forum member. I am going to buy a set of new bare casting heads, probably 95TM and have larger valves installed. Also on the wish list is 1.8 roller tip rockers. I want to covert to coil on plug ignition using the edis as the controller. With the coil packs gone I can route the intake for the M90 supercharger over the engine. I know the M5OD transmission won't handle the abuse, so I am working on swapping in a T56 6 speed. The van has a 3.55 rear end, I kept the 4.10 axle from the last van. It will get an explorer disc brake swap then installed. The bushings are shot on the upper control arm, I found a nice solution. A watts link for an 05-14 mustang and an adjustable upper control arm can be adapted. I'm still parts shopping but in my mind I've worn the tires off 3 times....
