phone holder for 2000 | Ford Explorer Forums
bigcrunch
2000 v8
I am looking for a stable phone holder that will put it little above radio 2000 Nothing that I have to glue or make permanent mods to dash-console etc. what are you using ? thanks.....
Good question! This is a tricky one with these dashes. The clip into the hvac vent style ones do not hold well on these dash
Nobody wants to put holes in the dash but unfortunately this may be the best option if you want the phone up that high.
I keep
Mine down in the
Cupholder until I can find a good solution
Interested to see what others have come up with
Mine came with a phone holder base that was held on with double sided tape. It was just the base and was easily removed. It was to the right of the radio and below the rear window switch.
Before:
After:
I want something eye level so I can see road easily and phone at same time and work the keypad. I have one that goes in CD player of radio but it wiggles out do to vibrations, perfect height but not reliable.
I've used this one for years. Super easy to use. sticks to your window with a suction cup, have to put a metal plate on th back of your phone but after that just holds by a magnet. https://www.amazon.com/SCOSCHE-MAGW...al-Magnetic/dp/B00I9I8WGY?tag=seriouexplor-20
