I just got a set of piaa 520's. They are 85watts each. I have a 30 amp relay and a 30 amp switch. I have 12ga running from the battery to a fuse to the switch and from the switch to the relay. All of the rest of the wires are 14 ga. Does this sound like an ok setup? Is 14ga wire strong enough for the piaa's?
Edit the power wire from the battery to the relay also has a fuse.
