Pic Request- Your Explorer Towing
OBX Gurl
Location
The Outer Banks of North Carolina
Kitty Hawk
1997 Explorer XLT AWD v8
Ill start the show with my pic-
Mountaineer Green, what is the weight and length on that trailer? How does she tow and did you mod the Mounty for towing with helper springs transmission cooler or brake control modulator?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
jbb0177
2018 Explorer Sport
What's the dry weight of your trailer??
[/QUOTE]
Indispensable Explorer
Tennessee
1995 Explorer XLT
This trailer is a fraction of what she used to tow. This trailer as pictured is not much more than 1,600 pounds, but fully loaded it will be around 2,000 lbs. The trailer was recently bought to haul (and store) mow equipment. The "hazard" has towed around 5,000 lbs on several occasions when it was the family's tow vehicle. (I currently don't have pictures but I will look for them)
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
2000 EB Explorer 5.0
Newer pic of Eddie towing our camper. The previous pics were while towing the camper back from the dealer. Now its equipped with an anti-sway connection, and booster shocks.
Took this pic after hooking up and loading before heading out for Tombstone AZ.
rowekmr
Chgo, IL
06 Limited 4.6 4X4
That's a nice looking set up. I love those 5.0l's had one and miss it. With the flowmasters and deletes it must sound real mean.
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
Thank you! The trailer does tax it, but It does ok. Sounds good. The inner youth wished it was louder but the mature adult realizes it would make conversation more difficult. LoL.
Hardest part is making sure any upgrades serve all uses... Daily driver, tow rig, and off road toy.
rmkilc
Vancouver, WA
2015 Ford Explorer Sport
I just came across this thread so I thought I would put up some of my towing pictures.
willied
Columbus, GA
2006 XLT V8
So how do the two Explorers compare to each other in towing? Pretty big loads ya got there!
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
That Big Tex is squatting that Explorer pretty good. I’d look into a bag setup if I was towing that thing with any regularity.
rmkilc
Vancouver, WA
My 2000 is rated for 6,620 lbs whereas my 2015 is rated for 5,000 lbs. The Big Tex dump trailer weighs about 4,200 lbs empty. With my 2015 I have only towed it empty and that was more out of curiosity than anything as there isn't much room for payload.
To be honest, my 2000 is a lot more confidence inspiring. Even with the dump trailer loaded up versus an empty trailer behind my 2015. There is a section of road that is downhill and needs repaved real bad. In my 2015, I have to take it easy and the steering feels floaty. But in my 2000, I can cruise through it with no problem. I'm not sure why that is. Perhaps part of it is because I have a lot more experience towing with my 2000. Part of it could be because my 2015 cabin is so quiet, a lot of noise comes through the trailer hitch which kinda throws me off whereas in my 2000 the cabin is already loud and adding a trailer hardly makes a difference. Part of it could be body-on-frame vs unibody. I have the same model Tekonsha P3 trailer brake controllers in both.
In my 2000, I don't see transmission temps over 200° even on long tows. I do have an electric fan installed behind the OEM transmission cooler and a thermostat to turn it on when the fluid gets above 170°.
As far as transmission and PTU temps go in my 2015, they were both normal on the one tow I did with the big trailer. Transmission never exceeded 205° and PTU never exceeded 180°. But it was only about a 10 minute drive although it was hilly.
Currently I have generic short add-a-leafs installed but I'm not very impressed. I do have real proper vehicle specific add-a-leafs from General Spring that I haven't installed yet.
Mbrooks420
High Voltage.
EF Vendor
I put a bag kit for a Bronco in my old 98 when I carried ridiculous tongue weights. Was a huge help. With two dirt bikes hanging on the hitch it was way nicer.
kmack
San Antonio, TX
1993 Ford Explorer
Total towing weight is about 3,200 lbs
BrewCrewX
Arizona
2010 Ford Explorer XLT
Picked up my new camper yesterday. Pulled pretty well, stuck around 55 with OD off (26-2800 RPMs.) Trailer is around 3,400 dry. My only real concern is no way to determine transmission temp. I have a OBD/Bluetooth plug-in that connects to my phone but transmission temp was not an option to view. Truck is a 2010 V8 4x4 with towing package. Might have my local shop look at installing a temp gauge for the transmission.
For those wondering, average 10.6MPGs. Husky weight distribution hitch with passenger side sway control and brake controller in truck.
O Yes I did search ...looking for a pic Tow Rig Forum 4
I Towing Mirrors for 2015 Explorer? Tow Rig Forum 0
M Installing Neutral Tow kit in my 2010 Ford Explorer Tow Rig Forum 2
M 2010 Explorer 4.0 v6 towing capacity? 5205lb? Tow Rig Forum 6
B 2016 Explorer, no tow package HELP!! Tow Rig Forum 9
J 2018 Explorer Sport - Towing a Travel Trailer Tow Rig Forum 47
M 2006 Explorer w/tow package electrical problem Tow Rig Forum 2
D 2012 Explorer XLT adding 7-pin without factory tow package Tow Rig Forum 11
C Towing Camper w/ Explorer Sport V6 AWD Tow Rig Forum 19
skoville Wanted Need to get a Explorer unstuck. Tow Rig Forum 6
C 96 Explorer - Eddie Bauer - Trailer Harness Tow Rig Forum 1
C Using a tow dolly for 97 explorer sport Tow Rig Forum 2
4 Towing issues with lowered 5th gen Explorer? Tow Rig Forum 3
J Towing Trailer Length for an '07 Explorer Tow Rig Forum 4
S 2016 Explorer XLT - Aftermarket Tow Install Tow Rig Forum 3
V 98 Explorer loading/unloading a boat Tow Rig Forum 5
F 2013 Explorer Brake Controller Wire Harness Tow Rig Forum 1
M 2016 Explorer Sport boat/small trailer. Tow Rig Forum 7
R 2016 explorer 2.3L dealer install "factory" tow package Tow Rig Forum 1
P 2008 Explorer Class 2 towing HEIGHT problem Tow Rig Forum 3
J 1996 Explorer Trailer Wiring Tow Rig Forum 3
J 1995 Ford Explorer with no right turn signal or brake on popup camper Tow Rig Forum 0
M 2016 Explorer Brake Controller connection under dash Tow Rig Forum 9
G '03 2-door Explorer - are we being safe? Tow Rig Forum 8
E 04 Explorer 4x4 with Class II hitch Tow Rig Forum 3
L 2014 Explorer Sport and Boat Towing Tow Rig Forum 5
Number4 Loading an Explorer on a tow dolly Tow Rig Forum 3
E '03 Explorer - first time towing! Tow Rig Forum 3
C 2015 Explorer towing Tow Rig Forum 3
C Tow One Explorer With Another Explorer ? Tow Rig Forum 5
B pulling explorer out of snow Tow Rig Forum 3
W 2wd 6cylinder 2003 explorer - tow capacity Tow Rig Forum 2
M New Explorer Question Tow Rig Forum 1
B 2004 Ford Explorer - next choice ? Tow Rig Forum 2
J Trailer harness issues - 2003 Ford Explorer Sport Tow Rig Forum 0
MidnightRebel07 Who here flat tows their Explorer's, Sport Trac's, etc...? Tow Rig Forum 20
U 2009 Explorer suspension upgrade for towing? Tow Rig Forum 8
X Towing with 2011 5 th generation Explorer Tow Rig Forum 15
M Anti Rattle Hitch for 2010 Explorer Class II Hitch? Tow Rig Forum 1
E A V6 third gen explorer, some time, money, and a dream Tow Rig Forum 0
E 2002-2005 Ford Explorer Tow Hitch Bolts Tow Rig Forum 3
M '98 Explorer XLT 5.0 Trailer Wiring HELP! Tow Rig Forum 4
E 02-05 Explorer Towing Questions Tow Rig Forum 2
R UHaul and the Ford Explorer Tow Rig Forum 19
G 2013 Explorer, do I need a brake controller? Tow Rig Forum 8
E towing boat with 2 door explorer sport Tow Rig Forum 9
J 2011-2014 Explorer Tow Button Tow Rig Forum 1
J Need help deciding what to buy - explorer or 4runner Tow Rig Forum 5
K Trailer Wiring Problem on 1994 Ford Explorer Eddie Bauer Edition Tow Rig Forum 0
S 2013 Explorer Towing Noise Problem Tow Rig Forum 13
Similar threads
