Pics of TT Shackle and AAl | Ford Explorer Forums - Serious Explorations
skia4life89
Lenoir NC
1999 LIMITED
Hey guys I have 99 Limited Ex and I ordered the Warrior 153, Procomp 13120 short AAL and plan on doing TT. I searched but couldnt find a thread dedicated to pics. So anybody out there running this setup that can post pics so I can get an idea of what mine will look like?
Thanks guys.
I don't have the AAL set up, but, I have the Warrior 153s and a 4dr rear leaf pack, aswell as a body lift and 285 75 16s...
Si
Yes... but with a 2" body lift. And 33" tires.
Check my registry.
I installed my AAL with a little TT to help match. Did the body lift. Got 33" tires. Added shackles and more TT.
So I don't if that helps you much.
Dang you guys are quick at the trigger:chug:
4dr leaf pack long Superlift aal and Warriors plus Monroe coil overs 285 75 16 tires
Warrior 153, Monroe SensaTrac coilovers in the rear, 4dr leaf pack, and Rancho RS5000 in the front. Still have to do the TT in the front.
33's, AAL, WAR153 Shackles, Max TT, 1" BL
Front fenders have been cut back two inches to make room for larger tires on a smaller lift.
Check my thread in my sig. I have pics of my sport with that set up.
My signature shows what i have done to it...here are some pictures for more ideas:
check my registry. sitting stock tires. TT upfront, Shackles and AAL. i also have the numbers of what i started at and what i ended at after the lift
Throw in a PA883 3-inch lift, and here's what you get.
post AAL:TT 06-03-12.jpg
Man, I need some bigger tires.
:exp:
its not an EX but here was my truck with just the TT about 2" worth and the procomp AAL. running 31" goodyear silent armors at the time i think...:scratch:
'95 w/ 2" TT, Pro comp short AAL, drvr/psngr leaf swap, Warrior 153 Shackles, 31s
TT and autozone shackles, about 2 inches front and back. 235/75/15 tires, greatly improves the look IMO
1998 XLT 2wd 5.0
00 XLT AWD, TT/AAL/Shackle, 265/75r16 Mastercraft Courser AXT
TT and Shackle Lift. 265/75/16 BFG All Terrains.
What is tt/aal lol
Torsion Twist and Add-A-Leaf. Both extremely cost effective ways of lifting the trucks. TT is for the front and AAL is for the rear.
Shackles are also for the rear, it seems like alot of people combine shackles and AAL.. I was going to just do shackles but considering how cheap the AAL is, I might as well do both at the same time.
