Pillar spotlight | Ford Explorer Forums
Pillar spotlight
kunit50
National park, nj
2017 Ford interceptor uti
Hey guys. I just got a 2017 fpiu. The dealership took out the spotlights, but I wanted to replace them. The outer chrome grommet is still attached. Would you guys know where I can find one for the driver side and passenger side?
Not standard equipment, correct
But most likely was a factory installed option(s) on your unit - at least the spot installed on my '19 PIU was a factory option, as listed on the window sticker.
As far as installation instructions, have a look at the attached doc from Unity (Manufacturer of the factory installed spotlights), along with the spec sheet for the unit itself. The unity website has a bunch of detailed info and links.
And welcome to the site
Welcome to the Forum. :wave:
The spot light and the 'A' pillar housing are not standard equipment. That was done as part of the police upfitter's work especially for the PIU.
If you wanted to mount one on the passenger side it would involve drilling both the 'A' pillar plastic moulding and possible the frame.
Check out this post re the spotlight acquisition; Spotlight installation
Install video; https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwie0rPi3eqGAxWKE1kFHc8kAUAQtwJ6BAgqEAI&url=https://www.youtube.com/watch?v=eA5WqLYhxaY&usg=AOvVaw20kDK-Se4VDreDLdGhNfV4&opi=89978449
Peter I have the housing on both sides. The lights were installed before. Just unhooked prior to me buying the vehicle. I just want the light/handle and wire. I have everything else
