Pinstripe Removal.... | Ford Explorer Forums
mf94_4x4
Massachussetts
2007 Mountaineer
I have 94, 4 door with a factory pinstripe which i belive is some form of sticker tape or something but its stuck on there realy well.. I want to remove it all from my truck, anyone have any suggestions on how to go about this.....I though if i heat is up and try and peel it off with a plastic scraper then clean the sticky goo with some Goof Off or something.........any suggestion is helpfull. Thanks
Sounds like you've got it figured out already. There are quite a few threads on pin stripe removal if you do a search, but that's basically what everyone else has done. I didn't use any special tool to remove mine other than my nails. One problem could be that there is a clearcoat over it which someone else ran into recently also.
thnx guys, ill try it out when im home in a week or so... :)
