Pipe Size | Ford Explorer Forums
Pipe Size
MAS Tequila
Boca Raton FL
2015 PIU
I hope this doesn't double post.
I'm looking to order parts to play with the exhaust on my '00 Mountaineer 5.0 AWD.
Does anyone know offhand what size the exhaust pipes are just in front of the secondary cats?
My plan is to cut them out and run something different on back.
TIA
MT
2.25" pipe for everything behind the collector flange if I'm not mistaken
So if I cut the secondary cats off, a 2.5" pipe will slide over what's left?
MT
2.5" will slide over but it will be too big to clamp. You need to use 2.25" tube with the end expanded for a slip fit. Weld or clamp it to keep it in place. If you want to upsize to 2.5" you will need to buy or make a transition piece.
