Big6ft6
- January 3, 2007
- Madison, WI
- 1997 5.0 AWD
I bought this 01 limited a couple weeks ago with a undulating noise coming from the drivers side front wheel. Since my mechanic did a pre-purchase inspection and said it needed a new wheel bearing, I assumed that was the cause of this noise, sounded just like a bad bearing or bad/uneven tire tread.
To shorten a long story, I've done a bunch of rebairs: new hub, sway bar link was broken on passenger side, and driver side upper conrol arm rear bushing was shot (very shot, bolt was dented), newer tires but rotated them anyway to see if it would change anything and I still have the original noise.
The noise is very annoying it is strongest at about 36mph and gets louder if I take my foot off the gas as the truck coasts down through 30 mph. The noise is a very low noise like a subwoofer and cycles every revolution of the tire. It is quiet enough that passengers don't notice over conversation, but when I'm driving alone it is all I hear!! It is so low it is almost like a pressure wave and I can feel it slightly through feet and hands. I would make perfect sense if I had some sort of tire tread imperfection, that is exactly what it sonds/feels like. But I've flipped front to back tires and the noise is still there. Interestingly it seems worse with one tire than the other??? There are no noises from any of the other three wheel spots of the truck.
Please help me with ideas for the cause of this noise? I'm going insane
Would the parts I had to replace suggest the previous owner slammed into a curb with driver-side front wheel?? If so what might this have dammaged that would give me this noise?
