dawnsandstaylor
- January 5, 2014
How the story began……….Went to 2004 Ford Explorer, tried turning the ignition; nothing happen. No lights, no sounds from doors, nothing! So we popped the hood and put in another battery. The battery is smaller than the one that was in it. Once the battery was in, noise came on, radio, lights on dash, power locks working, wipers, etc.:
Trying to start vehicle:
Once we put the battery in we attempted to start the vehicle and nothing happens. No “cranking”/starting.. It just sitting there does nothing.
Key stuck
When we tried to take the key out, the key won’t come out unless with take the negative cable off battery. We then discovered that you had to play with the shift in order for it to go directly in park. So that problem was solved.
Second Attempt:
This didn’t help, vehicle still wouldn’t start. We tried disconnecting battery and leaving key in; still no turning over, cranking, however you wish to call it.
Things we noticed:
1. When the key is to on Position, the theft light flashes rapidly. After five minutes with key in the on position light goes off. After we try to start vehicle again, lights comes back on.
2. When the vehicle is in on position when we turn the a/c on, the vehicle power shuts off. This means the dash board completely. Once the a/c goes off the dash board lights back up and gauges return to normal.
3. The a/c is on but no air is coming out.
4. Fuel pump is not running; no power
5. When we mess around with the window (going up and down) Radio blinks in and out.
Things to consider.
1. The vehicle hasn’t been started in over four months before battery replaced.
2. The copied no chip key was put in, trying to start it.
3. There is a click sound from hood
4. There is a click sound from under the driver’s wheel…..
5. We tried jump starting from starter; just keeps rolling over.
Key stuck
Second Attempt:
Things we noticed:
Things to consider.
