plug and play hid kit question | Ford Explorer Forums
uchi
niagara falls ontario
2001 sport
im just wondering if its as simple as that with my 01 sport. my last car had a plug and play kit and i ended up having to hardwire the lights into the car because one wouldnt fire using the factory wires. also if i need to hardwire them in is it as simple as using the factory power wire to trigger the relay? my last car had this stupid setup where both wires recieved a constant power supply and one turned into a ground when the lights were switched to on.
Are you asking which wire is witch on the head lights?
What are you even working on? You ask if its as easy as your 01 sport and your profile says you have a 01sport?
Yes, it will be plug and play..
yeah sorry i should have been clearer. heres the kit i bought
http://www.vvme.com/product/detail-20022.html
it says plug and play. will it be as simple as plugging my connectors into the harness provided or do i need to cut off my connectors and wire them through a relay and get power from the battery? or is there sufficient power coming through my stock wiring to power these lights?
