PML 6R80 trans pan installed | Page 2 | Ford Explorer Forums
I have a 2010 explorer sport trac adrenaline I would like to replace the trans oilp but auto performance says they don't have one to fit.
what I would like to know is where did you get the oil dip stick kit.
this is one of the dumbest ways to fill a transmission with a 3" stick next to the exhaust sys with the motor running.
I used the Mustang pan and dipstick kit. They didn't have the F150 kit available at that time. I mounted mine to a small ( 6mm I think ) bolt already existing on the fire wall. What I bought was a coupling nut, bolt and washer. The coupling nut threads right on install bolt and washer through bracket and thread into open end of coupling nut. It is solid and works great. You may have the bend the bracket to an acute angle to allow the handle to clear the fire wall a bit... :usa:
I know, old thread...if the Mustang dipstick kit works, then I'll use that one and save 100 bucks!
