ahkistler
- August 26, 2011
- California
- 1997 explorer awd
Hey all,
I'm in the process of resurrecting a 1997 AWD Explorer. It's been a tricky endeavor thus far. I'm now stuck on trying to figure out a popping on acceleration.
The work I've done so far includes:
1. replaced CV axle (driver's side I think, it's been a while)
2. replaced viscous coupler/rebuilt transfer case (used to have an ungodly loud popping noise on turns - fixed!)
3. Swapped Front drive shaft with one from a they-pull-it car yard (Are there different lengths of drive shafts within a cm of each other? because the original removed very easily the replacement I had to loosen the front differential mounts to get the driveshaft to fit)
4. Opened and inspected front differential, everything looked fine so resealed it.
5. New radiator (There was transmission fluid in the radiator, and water in the transmission, transmission was flushed/new filter put in as well as drain nut; trying to flush all the water out)
Summary: Used to pop on turns, no popping on acceleration. After rebuilding transfer case and reinstalling, all popping was gone. Replaced radiator and dropped the pan (may have removed front driveshaft) and once everything was back together, it started popping on acceleration. If I very gently accelerate, it doesn't pop, if I give it more than ~20% throttle, it kind of clunk/pops until over 25mph.
I'm wondering if removing and reinstalling the differential mounts might have something to do with it?
