rocketcouch
- December 11, 2013
- Massachusettes
- 95 ford explorer
so this all started about a year ago when i noticed that on the highway i would get a slight intermittent jerk in the car. pretty much say a loaded misfire. it has slowly gotten worse to now where i cant get on it and as soon as i blimp the throttle on the highway or try to drive it up a hill in 5th itll give that misfire in the exhaust. if i put it in 4th its better. the last two oil changes i saw a very little amount of milkey white which i know is moister but im not losing coolant so i didnt jump to that. the last oil change i noticed it seemed glittery which is usually ring material. plus ive lost almost 100miles per tank in gas.
this week ill be planning to do the head gaskets. ive changed every sensor on this thing except O2s and it doesnt burn any oil. the intake gasket has been changed and i noticed the passenger head has new rocker shaft and new springs so im thinking its been off recently. the head bolts are rusty so theyve been reused or its been a while since the head(s) heave been off.
ill probably do a compression test too before its all off but im thinking head gasket but i want to see if anyone agrees
