zman7125
- February 16, 2012
- Buffalo
- 2000 Ford Explorer
Hey guys I think the front drive shaft on my 2000 Ford Explorer 5.0L V8 AWD is on its way out. Since I bought the truck its had a slight vibration to the front end. I had the entire front end replaced (Sway Bar Links, Ball Joints, Tie Rod Ends, Wheel Bearings/Hub, Both CV Axles) in addition to balancing the tires and it still has a vibration that seems to be getting worse. The truck has the typical bind/growl when at low speeds and turning as if I was in 4WD on dry pavement. The truck only has 60k on it but is 14 years old and the truck is extremely rusted underneath. The tires are all the same and have the same amount of wear and tire pressure.
I found this driveshaft from Advance Auto Parts that I could have shipped to my house, was wondering if anyone's had any experience with them? If not which route should I go? Thanks for the help in advance!
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_driveshaft-crs_10335255-p
