chron_bon
- January 20, 2019
- Vancouver
- 1993, XL 4 Dr 4x4 315k km
Hey,
So my explorer has power seats that must have been installed by someone a while ago, and look very hastily put together. Currently, the connector isn't getting any power. They don't look like they were properly done, based off of the gauge of the wires used. Not sure what it is exactly, but somewhere around 20AWG.
So, the seats have never worked for me but were in a position that fit me well. But now some friends are going to be borrowing it and will need the seats to be adjustable, so I'm planning to get them working.
My first step was just checking the fuse underneath the hood, and it wasn't there. So I put in a 60A fuse, which is what the image in the fuse box called for for the power seats, and still now power to the seats. This leads me to believe that the seats weren't getting power from the correct source when installed. I decided to check to see if any fuses were blown in the fuse box under the driver foot well in case they tapped off of something that couldn't handle the load, but all those fuses have continuity. At this point I figure I may as well wire them up properly.
I took a look in the Haynes manual wiring diagram and can't find the power seats anywhere. I've double and triple checked, but could still be missing them.
Could anybody provide a wiring diagram that shows which wire connects to the 60A fuse under the hood?
Thanks!
PS, the seats appear to be ford power seats for this model, and just require the 2 pin connector.
Thanks!
