IAmTodd
4x Explorer Veteran
- April 8, 2002
- Johnstown, PA
- 2015 Jeep
Well just noticed tonite my rack is leaking. Its only bad when you have the front suspension at full droop, its pretty much just running out then. There is a rip in the boot on the drivers side closest to the wheel and thats where its draining from. I would think that there should be no fluid in that boot which leads me to believe that there is a problem with the rack. Correct? Its not bad right now, so I'm not gonna worry about it.
If it does need replaced, how hard of a job is it? While I'm up there I might as well replace the sway bar bushings and see if one of those two is related to my mysterious thumping sound in the front
Thanks,
Todd
Thanks,
Todd
