power window problem | Ford Explorer Forums
blus
southaven.ms
98 sport
hello everyone it's been a while since I postedso here goes. '98 exp sport. I have no power windows and windshield washer/wipers on front. I left the window down during a rainstorm and the windows stopped right after. all fuses are ok relay contacts look good. I'm open to suggestions. thanks. by the way the electric door locks work fine.
I would take the switch apart (entirely), blow it all out with compressed air, and check for corrosion on the switch contacts.
ok thanks I'm on it. I'll let you know what I find.
Water also may have gotten to the wiring loom under the door sill.. Check under there too.
