power windows and keyless problem? | Ford Explorer Forums
tradar
Muskegon, michigan
1999, mountaineer
I am not sure if this is related? My windows all work on the drivers door, but don't work on the other doors "ALL" the time. Most of the time they do not. My keyless remote unlocks the doors, and panic button works but won't lock the doors.
1999 mountaineer 212,000 5.0 power everything.?
also I get a tire wear on:"INSIDE OF DRIVERS SIDE REAR TIRE,"
When you hit a slick spot the truck heads for the YELLOW Line and the rear end heads for the ditch, is this a worn bearing? or something I can fix before going to the shop?
Thanks for any help?
I don't the the tire problem and the windows are related... :-)
Anyways, the window problem is most likely caused by a "fubarred" lockout switch... can be cleaned... but should be tested with a meter. On the locks "thing"... IF your door unlock / lock switches work, then its a broken wire going from the RAP module in the cargo area to the corresponding lock relay.... IF your door switches don't work either, then it could be the lock relay (again in the cargo panel area) and / or a broken wire near there.
