gto78
- June 18, 2006
- stuart, fl
- 98 EB 2wd v-6
Ok guys, this is a rough idea of what I'd like to do to my explorer. Remove the SOHC engine and tranny, and 4:10 gears. Install a powerstroke 6.0 and tranny, and 3:23 gears. Sound impossible? I know the guys were mostly getting about 18-20 mpg stock out of the powerstrokes when they first came out with the 6.0 liter version- until ford screwed with the software and removed the pilot injection system along with messing up the fuel curve. Those same exact guys went from 20 mpg to 12 mpg and if you don't believe me then do some reading on ford truck enthusiast.com. My point though is that it's possible to reprogram that engine to it's peak fuel efficiency, install it on the much lighter explorer, match it up with some nice low rpm gearing, and still have gobs of torque left over to tow with. I'd estimate roughly 25 mpg and easily be able to tow 9,000 to 11,000 lbs provided you have the right tires and brakes. The best part is the ability to swap software and add 300 or more pounds of torque. The stock torque on those engines is 560 lbs and 370 hp.
My main concern is the added weight, and how to stiffen the front suspension to bring the height back to normal. If I remember correctly, the powerstroke drivetrain weighs around 1300 pounds!
Has this been done before? If so I'd like to get some info from whoever did it.
