Preforming a Torsion Twist | Ford Explorer Forums
Team_RamRod
Boston, MA
'99 XLT
I looked around for a while now and it seems like this would be a cheap and easy way to put some height on my truck. I have no idea how to do this. If I do this is there anything I need to get so I don't mess up the truck?
Thanks for any help
Do a search. It's a simple process of turning the torsion bar adjusting bolts. You will also need to lift the rear though, a set of lift shackles (warrior) will do that for you. Again, do alittle searching, you'll find litteraly TONS of threads about this mod that will get you well on the way :)
You can lift the front up it you want but i did mine on the ground, but go under there look for the two bolts where the torstion bars are tighten those up and do all or shackles in the rear i did both on mine then get an alignment.
Thanks for any help
it is very simple to do only thing is it is tough to stop there
welcome to the site another boston area explorer..
also autozone sells shackles i have had for 3 years a nd have had not one issue with them and cheap also$$$$
Here is the procedure for giving your late model the inches you desire, while we wait for the aftermarket companies to design and market a true suspension lift. It can be accomplished by anyone who is mildly mechanically inclined and only requires the following tools:
1 can Liquid Wrench (or any penetrating oil)
1 Jack and Jackstands
1 Socket Wrench
1 Measuring Tape
1. With the truck level, measure the distance from the center of the wheelwell lip to the top center of your wheel on each side. Mark the distance for each side, it will be important for two reasons. First you want to ensure that both sides are level when you're done, and second you want to limit the lift to no more than 2" from stock. (Any higher will cause stress to your CV joints, resulting in accelerated wear and possibly failure)
2. Now jack up the front end and secure on jackstands to take the pressure off the torsion bars. Slide underneath and find the two adjuster bolts located near the back of both torsion bars (towards the rear of the truck) and spray liberally with some Liquid Wrench. Let it soak in for 10 mins. to free up the bolts. Using the socket wrench, tighten up the bolts until they are almost to the end of their travel. This will torque up the torsion bars, causing them to lift the front end higher. Now lower the front end and take the same measurements as you did before you began, to determine the lift gained. Repeat the tightening/loosening of the bolts until both sides are level and lift gained is no more than 2".
3. Take the truck out for a 10 minute drive. This will cause the torsion bars to "settle" and will most likely give you 1.5-1.75" of final lift, which is ideally where you want to be. The rear can be lifted using either extended shackles (limited lift) or by adding an add-a-leaf (full length recommended). After the rear is lifted and you're content with the new height, be sure to take your vehicle to get an alignment, as you may have altered it after the torsion bar lift. The combination of torsion bar lift and add-a-leaf does firm up the ride, but in my opinion improves it and in no way degrades it. The Explorer is already a soft riding suspension, and after the lift body roll and nose dive is almost entirely eliminated. So much so that I will be removing the rear swaybar in order to improve articulation (wheel travel).
It’s readily accepted that the late model Explorers will fit 31x10.5/15 tires at stock height, as my ’96 did. I only experienced slight rubbing in the rear, and only during full compression while off-roading. After the 2” lift front and 2.5” lift in the rear I have yet to experience any rubbing at all, even when putting the suspension to it’s limits. I’m confidant that 32s could be easily fit after the lift, but I’m looking at a set of 33x10.5/15 tires to replace my 31s, once they are worn down, which will give me the height I desire, without the worry of rubbing from having too wide a tire.
Good luck.
Go SOX!
cgriffin_5139 nice job explaining the hole procedure- not sure if thats a sticky or useful thread but the way you said it makes it worthy I think.
Patton said:
Will adding a torsion twist or warrior shackles effect the installing of a body lift kit in the future?
No, the installation will be the same.
-Rich
The thread I refered to in my first post is a sticky and has pics! Nice job explaining cgriffin_5139. Maybe yours can be added to that thread for more reference.
-Rich
I don't have a jack so is there any way i can do without?
I think I know the answer to this question though.
goto walmart and get 2 jacks. they wont cost you more than $30
Just bought a jack and two stands from O'Reilly's for $20.00. Im sure whatever local parts store you have will have close to the same deal. Get it when you get your shackles.
BTW, your car came with a jack.
I did mine with out lifting the front tires off the ground. I just slid under my Mounty with a 24" long 1/2" drive ratchet and little bit of liquid wrench.
Bada bing 1-1/2" of lift.
when i did my retortion bars me and my buddies jacked up the frontend and hit the retortion bar bolts with an impact gan and that did it !!REALY!! fast.
but thats just me.... a long socket wrench with a breaker bar also works well 2
