Ok, I searched around and this is what I've come up with for prepping the plastic trim:
-some people said 200, others said 600 grit sand paper (it matter if wet or dry?) any special technique to sanding?
-prime it (what type of primer?)
tape off, sand, prime, sand, prime, sand, paint.
That sounds about right? I just need to know what grit to use and when
I'm worried about using masking tape to tape off - will it take off the clearcoat when I take it off? My friend's 95 civic had something painted, and they used masking tape to tape something off, and when they removed it, it took a nice chunk of clearcoat with it.
Also, how long do I need to let the paint dry before I apply clearcoat? And lastly... I need to repaint a corner on my rear bumper... I've heard that I can just repaint that part and then blend it in w/ the rest. Does blending just consist of pulling the paint gun slowly further away from the paint as you get further from the repaited spot?
Thanks,
Patrick
any how-to pics would be helpful =P
Thanks,
Patrick
