jweb1369
- October 3, 2008
- Panama City, FL
- '99 Sport
I changed my oil like normal. Pulled the drain bolt, and took off the old filter. Once the oil stopped draining, I put the bolt back on and installed the new filter. I added about 3 1/2 quarts of high mileage pennzoil, and proceeded to check the oil level via the dipstick. I checked it first without starting the truck, then again after I started the truck. The reading was WAY over full.
So, I took about a quart out. Checked reading again, the same... WAY over full. It didn't even look like the level went down. I drove it around the block and check again, the exact same. WAY over full. I don't want to completely drain it again... I know the amount I pulled out has to be more than I put back in.
Every car I ever changed oil on took at least 5 quarts. I used to drive a mitsubishi eclipse and it took a little over 5 quarts, and the engine was much smaller. By WAY over full I mean like two more of the hatched (marked) parts higher. I'm dumbfounded. What the hell is going on?
