cargirl51
- November 27, 2014
- Warrenton, VA
- 2004 Ford Explorer XLT4X4
Hello everyone and thanks for allowing me to be a part of this forum. I am not too computer savy, so be patient. We own a 2004 Explorer XLT 4X4 purchased in December 2003. Vehicle only has 40,427 original miles on it. We have done all required maintenance/oil changes/fluid changes, etc. Truly, the vehicle looks like it is brand new. However, I need help with an issue we are having. When moving the car frontwards or backwards from a stop, the front end exhibits a shudder, a binding in slow speed turns and sometimes a noise from the front end. We have had this issue for a while but it is getting worse. We have been told it is normal with the control trac 4X4 option. The 4X4 works on the vehicle - engages and disengages. I am wondering if any other members have had this issue and how they got it fixed. I see from a Technical Bulletin some vehicles with an 8.8" limited slip rear axle may exhibit the chatter shudder, a binding sensation or a vibration during low speed turns. On 4X4 vehicles, the sensation may appear to be originating from the front axle or the steering gear. The bulletin gives directions on isolating the rear axle to verify if it is the rear axle and to replace the limited slip clutch pack. Before I take it to a dealer for them to try and figure it out, I just wanted more information so I can be better informed and able to follow the mechanic's/service advisor explanation. Thank you.
