bgarib
- February 4, 2014
- 2000 Ford Explorer
Hi everyone, so I've read tons of threads on blower motor problems. My 2000 Ford Explorer Limited is having issues with the blower. I have the automatic environment control thingy. It stopped working one day. When driving on the highway I still get some heat radiating out of the vents, but the blower for sure wasn't working. Here's what I have:
1) Took the blower motor out, tested it against the battery. It barely turned and smoked a little.
Tested a new blower motor, works great when connected to the battery.
2) Checked the fuse by the driver's door. A-OK
3) Checked continuity with the relay. Got the beep, looks good.
4) Checked continuity with the plug that goes into the blower motor. Got the beep, looks OK.
5) Checked voltage that the plug. I get -8 to -13 (depends on the fan setting). I only get that when I put the red diode to the orange/black cable, and the black diode to the pink one. All other combinations, including ground to the car, don't work.
So, the blower motor still doesn't kick on. Is this the blower motor resistor probably? Is there another switch in between the resistor and relay that might be the problem? HELP!
-Brian
-Brian
