Cali XLT
- January 6, 2013
- Ventura, CA
- 2005 Explorer XLT
Both front upper control arm bushings busted up at the same time... just outta the blue.
So I ordered a set of replacements and attempted to install them today.
I ran into a number of issues, mostly due to not having the proper tools.. so after a bunch of driving back and forth from Harbor Freight, I got it done.. well, sort of.
Since it took so much time out of my day doing the running around, I only managed to get the passenger side one installed.
The problem I ran into was with the ball joint bolt, or the pinch bolt. It would not go in all the way. I tried jacking up the knuckle to try to move the hole closer to the bolt, but it just pushed the control arm up along with it. There's about 1/2" of the flat surface of the bolt still sticking out.
I experienced a lot of frustrating with this today, so I got fed up and put everything back together, with that bolt not completely set.
What can I do to get it to go in all the way? I tried hammering the top of it, but it wouldn't budge. Am I supposed to lubricate it before I install it?
If I can't get it to go in any more, is it safe to drive to the mechanic to have them fix it?
I'd like to do the driver's side tomorrow, but only if I know how to install it correctly.
Any help would be very much appreciated!
Btw, the parts I have are Mevotech MS40116 and MS40117
