Ok so I have read through alot of threads and even different forums to see if I can find an answer to resolve all my problems but it seems like everything could be it and I really don't want to buy this and that and another of this and that just to find out it isn't the issue.
So if someone can help me rule out and better narrow down my options I would really appreciate it.
I have 2003 Ford Sport Trac XLT
It has the 4.0L SOHC engine and has less than 80k miles on it.
My first problem started 6 months ago (before that everything seemed fine)
When starting the engine, I would have to crank (not sure if that is the right word... I meant turning the key and holding it to start the engine) twice to get the car to start. Lately, it has gotten as bad as 3-4 times (on and off) to get it started and when it does finally start, it acts as if it is slowly getting power almost like a flashlight with low batteries, the light comes on but faint.
Here is what I've also noticed: When I fill my gas tank to full, even if the car has been sitting overnight, when I turn my key, it starts like nothing is wrong.
Any less than empty, it just gets worse and worse and more I have to try to crank it to get it to start.
In order to resolve the issue I have (since battery is only about 2 yrs old) replaced the spark plugs, its wires, and fuel filter.
That actualy made no difference to the currect problem and suddenly I have another major problem.
The more pressing problem is that now, when I drive, I cannot go uphill without loosing speed (and on good days where I've got some momentum before getting to the hill, then I can maintain the speed but never increase).
I cannot step on the gas and have my truck... just go like it used to.. it just slugs along and gradually and painfully slowly picks up speed. I'm actually suprised no one has honked at me because of my slowness in picking up speed.
It is like it no longer has power.
I know my transmission works fine, because eventually, when i keep picking up speed I can feel it shift and see that reflected on the RPM.
During careful driving I can force my CEL to flash by simply flooring my gas (which don't worry doesn't move as fast as it should so it is pretty safe when done at low speed or from stop)
I can force CEL to stay on by continuing to floor the gas after it has flashed.
I have taken it to a nearby mechanic who checked all the spark plugs, the wire and found them not to be the issue.
The mechanic says that his code reader shows:
Random Misfire
Cylinder #1 Misfire
Cylinder #3 Misfire
he could not see why because apparently according to him his universal code reader doesn't get details because apparently according to him for Ford, you really have to take it to the Ford dealers and their readers are the only ones that can get that detail?!?!
I went to Auto Zone since i know they're free and found that I am getting:
Random Misfire
Cylinder #3 Misfire
Fuel Injector #1 problem
Crankshaft Sensor problem
So in order to try and resolve the issue, I got the Fuel Injector and the CKP sensor.
I was able to get the CKP replaced with no difference in performance.
I cannot figure out where fuel injector #1 is located so that is pending.
Does anyone have an idea of what my underlining problem is?
If I can find a way to easily rule out what it isn't I think i would be much better off.
Some things I already saw people doing with similar issues:
Replacing Fuel Pump
Replacing other sensors (oxygen, and ICA?<-- haven't gotten to researching that one yet)
Rebuilding engine
Replacing cylinders
and much much more...
If you haven't figured it out, I'm obviously a newbie when it comes to automotive mechanics... any help would be very appreciated.
Random Misfire
Cylinder #1 Misfire
Cylinder #3 Misfire
Random Misfire
Cylinder #3 Misfire
Replacing Fuel Pump
Rebuilding engine
Replacing cylinders
