Problems with 2000 Explorer Sport | Ford Explorer Forums
2000Sport
Rawlins, WY via Flint,MI
2000 Explorer Sport
Ok I have 2 problems with my explorer.
1. When its hot out ( around 80 or higher) when I start it up it runs really rough for a minute. It doesn't do this in cooler weather just when it is really warm out.
2. Whenever I stop my ABS in the front goes off. I replaced the rear brakes and checked out the front ones. Everything seems to be ok. I can't just pull the fuse cause then my speedometer and odometer do not work. I has graudaually gotten worse over the past year.
Any help would be greatly appreciated!!
Thanks!
#1 sounds like either a bad temperature sensor or Idle Air Control (IAC) valve.
#2 may be a faulty abs sensor or maybe dirt in the sensing ring.
How would I go about figuring that out?
Could it be anything to do the the EGR Valve?
