Problems with Hella 500 Fogs | Ford Explorer Forums
dsturch1
Pennington, NJ
03 4.0 XLT & 98 5.0 XLT
Alright well today I picked up a set of Hella 500's to mount behind my billet grille I put in the explorer. I finally got everything all mounted and the wires run and for some reason its not working still??
Wondering if anyone has had any issues with this before? I was also wondering...on the explorer which wire is the positive feed to the highbeams? For now I ran the feed to the switch that is supposed to be tap spliced off of the power off the battery. This should still work seeing as the wire off the battery is a positive 12v feed also?
If anyone can help me out i'd appreciate it since me and wiring get along about as well as oil and water. lol.
Check your wiring compared to the diagram after some time (day) to think about it. If all still looks good, grounds are the first to check. After that the hot side.
Use a test light(about 4.00) to find which is the high beam wire. Colors veri yr to yr.
