Isaac
- September 20, 2001
- Williamsport PA.
- '92 XLT 4X4
Hi,, I recently bought a 92' Ford Explorer, and I got it very cheap, it had been in a small crash, on the drivers side there is body damidge, and also from what i can see and also the alignment tech that has worked on it,, cannot find any bent or damidged frame or suspensoin parts.
the truck has always pulled to the right, took it in and they lined it up twice, to getting both the caster and camber perfect with factory specs.
(the caster on the passengers side was way out in the front)
The truck still pulls to the right, not as bad as before but it still pulls,, i took it back in and they put it back on the rack,, and everything is in,, they switched tires around seeing if it was tire pull,, still not going straight.
the stearing box seems to have some "slop" in it.
could this be the prob?.
Thanx for any help you can give!!
