- March 4, 2007
- anaheim hills,california
- 95 ranger 4x4/ 91 X 4x4
Ok, i've got my front aussie locker in and i've done a bunch of reading up on it since i test drove it on a quick trail...I am looking for some answers for a first generation w/ifs and an aussie locker up front...
now mind you i do need some front tires and i am hoping this resolves my questions, but until then, i will ask something from the more experienced ones with front lockers... my question is, when i lock the hubs the locker is active while i'm still 4x2 and it steers the same in 4x4...it has the center steering in a direct forward direction and is difficult to turn...is this the way it is suppose to work....i can be driving along on dirt and go to turn and it pushes straight, it's kind of spooky...i guess why i am asking this is, will i have to wait till i drive up to a rock before i get out and lock my hubs because i need my direct line first???
i have read some of the brown wire mod and i believe it only pertains to 2nd generation X's...if my above question is true, something like the brown wire mod would work but i don't think it's possible on 1st generations...
i am also thinking i might have a tire size problem as explained briefly in the aussielocker.com info about tires have to be no more than 3/8" different and since both my fronts are evenly at the end of their life, this might be it, but they don't elaborate what the problem would be...i might even have an install problem that you guys can enlighten me on though the locker was easy to install and spec'd just fine...
any info from you warriors of the almighty front lockers would be greatly appreciated, thanks...
