Nate1
All 4 wheels locked
- December 4, 2002
- Gainesville/Tampa, FL
- '96 FZJ-80
I have heard both sides of the story, either you should get on it with a fully warmed engine asap to properly seat everything and get a full break in ( http://www.mototuneusa.com/break_in_secrets.htm ), or you should take it easy granny style and constantly vary your engine speeds for a good long distance (owner's manual style).
So, from a tech's perspective, which is the correct method? I can see the logic in both sides really, so I'm somewhat confused. I mostly want to believe the manufacturer and the research that they do, but then again there are definitely tricks of the trade that are not well known but do work.
-----Nate
-----Nate
