Proper fluid level BW4404? | Ford Explorer Forums
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
I tried to check the fluid level in my BW4404 and unscrewing the top plug (of the two located in the lower half of case), I had gushing out some ATF fluid, like a cup worth, before I screw it back in. Vehicle was level (more or less). Had anybody have that experience? Is that the proper way to check the level? Maybe I was not completelly level I guess?
The two plugs that I am talking about are the ones visible in this picture:
Well, I assumed that was overfilled while on a sloped driveway.
I drain it and filled with Mercon V - it took 1.25 qt, close of what the book said (1.3 qt).
SoNic67, how difficult was it to drop / replace your BW4404 transfer case? Needing to replace mine. My 97 Explore AWD is making that God awful “popping” noise when taking off from a stop sign / under load.
Also, what was your final thoughts on removing the front drive?
Thanks,
