imp
- November 12, 2009
- 59 Ranchero F250 D'Line
Oil Level and "Safety"
"Safe" oil level is a moot point, in reality. So long as sufficient oil is present in the sump to prevent the pump from sucking in air, instead of oil, the engine is protected. Be aware that vehicle "bounce", tilt, uphill, downhill, causes changes to the oil level relative to the pump pickup.
Most important, is that the LESS oil in the sump, the HOTTER the oil will be while running. HOT oil is undesirable, relatively speaking. Running the engine with oil level at low end of acceptable on the dipstick, will result in somewhat hotter-running oil than at the "full" mark. Just my opinion. imp
