BExplorer
- April 9, 2000
- Mirabel, Quebec, Canada
- 94' XL 4x4
A few days after I changed my front brakes, the truck started pulling to the left, but not always. Sometimes it goes staight, and somtimes pulls to the left. I have filled, sanded and greased all moving parts of the caliper. I also had the rear drums cleaned out and ajusted, I saw a small leak from the axle seal, but the pads dont seem to be soaked. Is it possible that the drum is grabbing and pulling on the rear end, when I brake it somtimes pull harder. I dont know if somthing would be loose in the front end, I checked: ball joint, tie rod, steering linkadge, evrything seems OK no play in them. What do you suggest.
