JoshC
Only rolled it once honey
- May 1, 2000
- Culloden, WV
- 97 4d OHV
I had codes P0300 and P0316. After some research on here I decided to replace the spark plugs and wires since they had 119K miles on them, needed done anyways. The truck had sit for a day or so when I installed them, so the first time it cranked up it was cold and with new plugs/wires. It started and ran like a champ. That was last night. This morning it's back to running pretty rough at cold idle. Put it into reverse and the combo of the ridiculous pressure on the gas petal and rough idle, it lunges into motion. Backing out of the driveway it doesn't run good at all. In drive, it does OK, taking off again is a bit rough, but it runs fine.
Little history-I had a tranny problem, took it into the shop and while it was there I asked the mechanic about the rough idle. At that time it was just a slight rough idle. Ford mechanic said, and I quote, "Ford invented the rough idle." Well, thanks, that got me the info I needed to fix the problem....:shifty_ey Took it to a tranny shop and had the tranny rebuilt. When I picked it up the mechanic told me it had a bad miss and that it needed to be looked at. He wasn't lying. If you were to have watched the tach, you'd think he swapped in a V8 with big cam. Got it home (ran fine on the trip home) and my wife got stranded with it, wouldn't start. Got it back home and discovered those two codes.
So, what's next? In a nut shell, new plugs and wires, still have a rough idle and a hard time getting it to take off in either direction. And right now there are no codes. Hate for the wife and kids to get stranded again.
