question about a lift | Ford Explorer Forums
bobbyt09
waldo fl
1991 4.0 4x4 with 31s
will a 4in suspension lift from a 96 ranger fit my 91 explorer???
If the 96 Ranger is 4x4 like your X the front should work. The Ranger is spring over in the rear and your X is spring under so most likely there will be problems with the rear.
Spring over is the way to go for the rear!! Front should bolt right up.. just make sure you have ALL the peices.
