Alex8706
- January 17, 2018
- Portland, OR
- 1992 Explorer Sport
I apologize if this is in the wrong thread. I wasnt sure which one would be more appropriate.
I just got new tires (265/75R/15) replacing my old ones (235/75R/15) on my 92 sport. First, great fit, no rubbing and the open country a/t looks badass on it. I want to change my driven gear to correct my speedometer. Im at a 5.9% (60mph shown 63.5 actual) difference according to a online tire calculator i used. Its not a big deal and its not very noticeable but its cheap and easy so why not. From what i understand a tooth changes it about 5mph so getting one less would make me closer but still one off. So based off of those numbers i would be good to just get one less tooth then what i have on my driven gear right now correct? Or would that make just make it show a higher speed than i am actually going?
Nest question is about the axle gear. Right now i am running the 3.27 (axle code 41). Is there any disadvantage to having that gear with those tires? Seems a little more sluggish really. I am considering getting the 3.73 as i heard it will balance everything out more between power and gas millage. Would i be required to change anything with the front axle also or would it be fine as it is with a 3.73 in the back while using 4wd? Lastly, what parts exactly would i need to buy to convert over to a 3.73 just the ring and pinion? If anyone could direct me to the parts i need that would be great too.
Thanks in advance. Sorry for all the questions might as well do it all in one post.
