merc2dogs
- October 22, 2004
- grand rapids Michigan
- 91 eddie
Hello,
I had the cel coming for a few minutes, then shut off, not flashing, on for a few minutes, then off for anywhere from a few minutes to an hour, stopped at advance auto on the way home, and had them pull codes for me
ended up with two seperate sets of codes:
111 system checks ok
Since the only definition I've ever found for this code IS "system checks ok", a question, does this mean the whole vehicle checks out good, or does it mean the obd system is working right?
also popped up with a 522, which was expected because I bypassed the switch, so nothing there.
as this didn't show anything I started home to dig in with a voltmeter to see if I could find any faults, on the way home the CEL came back on again as I was passing the next advance (yeah two close together, one at 68th, and one at 44th) so I pulled in and had them pull codes:
522 again
157 Mass Air Flow signal is/was low or grounded
171 Oxygen sensor not switching - system was at adaptive limits - Single, Right or Rear HO2S
173 Oxygen sensor not switching - system is or was rich - Single, Right or Rear HO2S
179 Fuel system was rich at part throttle Single, Right or Rear HO2S
once I'd gotten home I went through and checked out the engine and underhood wiring, and what I found was that the crank vent hose (from the intake tube to the oilfill) was off. apparently fallen off somewhere as it was gone, and the intake hose (tb to maf) was loose. put on a vent tube from the old engine, tightened up the intake hose and checked all the electrical connectors on the truck to make sure everything was tight. then had to make a 20 mile run, and the CEL never came on, which brings up the next question, would that vent tube, and the hose being loose effect the rest of the system and cause the codes and CEL?
In other words: How interdependant are the MAF, TPS and O2? I mean, if I have my foot down to go 50mph, and the TPS sees the same position as 50mph, but the MAF only sees airflow for say 35mph,will it kick in a richer fuel mix thinking I'm struggling up a steep grade making the O2 try to lean out the mix??
also the bypass I did on the clutch switch, would that effect anything? there has to be some reason for the computer to obtain that info,I figure if it reads clutch pedal position, it must use that info somewhere. It does keep the cruise control from working, it was bypassed because the clip was off when I bought the truck and the previous owner had a string and some other crap tied around it to keep it in place that was underfoot when I took the test drive, so when I bought it I bypassed it for the drive home and never saw reason to change it.
one more thing, second code reader gave the codes, but didn't print out the definitions as they normally do, just gave a 'no definition available", the operator, a normally competant guy I've worked with a lot, claimed that it was my on board computer that was supposed to be providing the definition, and since it wasn't, it (my computer) was faulty and needed to be replaced, to my knowledge, the trucks computer DOES NOT provide the definitions, just the code, and it's up to the reader to provide the definition (or up to the operator to translate them) am I wrong on that?
and, in case the guy was right about the computer being faulty, how well would a 91 EB explorers automatic computer work on the 92 with a stick? I know on the older rangers/B2's you could use the auto computer with a stick, but the sticks wouldn't work as well with an auto. simply because the trans controls weren't there.
ken
522 again
ken
