hardywo
- December 27, 2006
- Washington, DC
- '97 XLT Stick
Doesnt the kit require you to drill out the bottom body mount flange to 1/2" and then use a normal bolt with a nut? If thats the case, just hold the nut down with a vice grip while you torque on the other side.
Great idea!!! The instructions only said to do that for the front two mounts, but that should work for all of them. Maybe tomorrow- tonight's all-nighter will be doing the homework I was supposed to be doing this weekend.
So now that the body lift is done, what can I do about getting the grill guard to line up properly? Also, how did everyone else go about spacing out the bumpers? I've got a long piece of steel that I'll cut four 3" pieces from, drill holes in each and then use that along with two of the spacers that came with the 853 to make the "C-shaped" spacers for the front bumper, but I'm still confused about the rear one. Suggestions?
